Sensor+ Connect for Microsoft Edge (Windows Only)
In order to connect to a Sensor+ WebUI via Microsoft Edge, we must enable Internet Explorer mode, and then emulate IE 7 specifically. The following steps apply to Windows only, and cannot be performed on a Mac.
Windows Group Policy can block access to these tools. If you do not have access to the following settings, contact your IT department.
To enable Internet Explorer mode in Edge:
- Select Settings and More:
- Select Settings:
- Select Default Browser from the pane on the left:
- Choose the dropdown to Allow Sites to be Reloaded in Internet Explorer Mode:
- Click the Add button below:
- Enter the IP of the processor your are trying to connect to, starting with "http://". This dialog will not accept an IP address directly.
Once these steps have been completed, Edge will load the page in Internet Explorer mode whenever that IP is entered into the address bar. However, by default, Edge enters Internet Explorer 11 mode when loading a page. We still need to tell it to load the page in IE 7 mode to use Sensor+ Connect.
- In Windows, open the Run dialog box. For example, press the
Windows logo key
+R
. - Enter
%systemroot%\system32\f12\IEChooser.exe
, and then select OK. - Select the SensorConnect tab from the list of pages in IEchooser (it will likely be the only one listed).
- In IEChooser, select Document Mode 7, and User agent string "Internet Explorer 7."
Once these settings have been chosen, you can log into Sensor+ Connect.
