How to Upgrade a CEM Classic or CEM+ Sensor Touring Rack to CEM3
It is possible to upgrade your Sensor Touring Rack from a CEM Classic or CEM+ processor up to a CEM3.
To gather the needed parts, follow the table below to acquire all the parts you need.
For any additional assistance on this, contact ETC Technical Services.
Table of Parts
  1. First, find out which type of rack you have:
  2. Next the kit will change depending on if you are upgrading from a CEM Classic or a CEM+
    Upgrading From: SP 4820 SP 9620 SP 9620 Double Small
    CEM Classic 7143K1001 7143K1002 7143K1003
    CEM+ 7143K1005 7143K1005 7143K1005
  3. If this rack has Advanced Features (AF), you will need new AF Cards
    Note the amount of cards needed for your rack size
    Advanced Feature
    Cards
    7150B5623
    (Will need 2 of these)
    7150B5623
    (Will need 4 of these)
    7150B5623
  4. Next, you will need a CEM3 Processor, this is the same for all rack types
    CEM3 7140A1003 7140A1003 7140A1003
  5. Verify the existing door type of your rack and upgrade the parts according to the illustrations
    7143A2002
    (Will need 1 of these)
    7143A2002
    7143A2002
    7143A2005
    7153A3004
    7153A3004
    7153A3004
    7153A3007
    7153A3004
    7153A3004
    7153A3004
    7153A3007
  6. If you have a 9620 Double Small, verify the existing control input panel.
    If your control panel does not have an integral convenience outlet, you will be required to add this kit to your rack.
    switch.png NA NA NA
    noswitch.png NA NA 7143K1004
Related Links/References
