Phasing in Sensor Portable Packs and Touring Racks
Question
How are SP Portable and Touring Packs broken out by Phase?
Answer
Below are breakdowns for each portable pack ETC makes. In the newer Touring Packs the phasing is also detailed by the color coding in the patch bay. Black For Phase A, Red for Phase B, and Blue for Phase C.  Note that these dimmer #s assume each module holds two dimmers and takes up only one module space in the rack (e.g. a rack populated with D20 modules).
Legend for Images:
Single Slot Module: Refers to modules that take up a single slot in the rack (ex: D20, R20, CC20, D20AF, etc)
 Dual Slot Module: Refers to any module that takes up two slots in the rack (ex: D100AF and D50HR)
SP6
An SP6 spaces 2 Modules per phase.
A:
Dimmers 1-4
B:
Dimmers 5-8
C:
Dimmers 9-12
sensor_touring_racks_and_packs_phase_layouts_3%E2%80%90Phase+Layout+for+SP6.jpg  sensor_touring_racks_and_packs_phase_layouts_Single%E2%80%90Phase+Layout+for+SP6+%28b%29.jpg
SP12
An SP12 Spaces 4 Modules per phase.
A:
Dimmers 1-8
B:
Dimmers 9-16
C:
Dimmers 17-24
sensor_touring_racks_and_packs_phase_layouts_3%E2%80%90Phase+Layout+for+SP12.jpgsensor_touring_racks_and_packs_phase_layouts_Single%E2%80%90Phase+Layout+for+SP12.jpg
SP24
An SP24 (small Touring Pack) Phasing spaces a bit differently.  There are 8 Modules per phase but they are split into 2 smaller bus bars per phase of 4 modules each.
A1:
Dimmers 1-8
B1:
Dimmers 9-16
C1:
Dimmers 17-24
A2:
Dimmers 25-32
B2:
Dimmers 33-40
C2:
Dimmers 41-48
SP36
An SP36 (also Known as the Bandit Rack) In this rack there are 12 modules per phase splits into 3 smaller bus bars per phase except for phase B which has 4 smaller bus bars 2 with 4 modules and 2 with 2 modules.
A1:
Dimmer 1-8
B1:
Dimmer 9-16
C1:
Dimmer 17-24
A2:
Dimmer 25-32
B2:
Dimmer 33-36 (Bottom of column 1)
B3:
Dimmer 37-40 (top of column 2)
C2:
Dimmer 41-48
A3:
Dimmer 49-56
B4:
Dimmer 57-64
C3:
Dimmer 65-72
SP48
An SP48 (Large Touring Pack) Has 16 Modules per Phase split into 4 smaller bus bars per phase of 4 modules each.
A1:
Dimmers 1-8
B1:
Dimmers 9-16
C1:
Dimmers 17-24
A2:
Dimmers 25-32
B2:
Dimmers 33-40
C2:
Dimmers 41-48
A3:
Dimmers 49-56
B3:
Dimmers 57-64
C3:
Dimmers 65-72
A4:
Dimmers 73-80
B4:
Dimmers 81-88
C4:
Dimmers 89-96
