Replacement Patch Bay Connectors in Sensor Touring Racks
Description
If the "banana plug" on the end of a patch cable is worn out and needs to be replaced, you will need to replace the entire patch cable.
The "banana plugs" that ETC uses on the patch cables in Sensor Touring Racks requires a special tool to put on the end of the cable. Because of this, ETC sells replacement patch cables instead of replacement connectors. You can find the list of the various colors below and these parts can be ordered from your Local ETC Authorized Dealer.
7053B7006-1 PATCH BAY CORD REPL BLACK
7053B7006-2 PATCH BAY CORD REPL RED
7053B7006-3 PATCH BAY CORD REPL BLUE
7053B7006-4 PATCH BAY CORD REPL WHITE
7053B7006-5 PATCH BAY CORD REPL GREEN
7053B7006-6 PATCH BAY CORD REPL BROWN
7053B7006-7 PATCH BAY CORD REPL GRAY
7053B7006-8 PATCH BAY CORD REPL VIOLET
7053B7006-9 PATCH BAY CORD REPL YELLOW
Replacement labels for patch bay cords are attached at the end of this support article. The labels can be cut out and placed under the clear heat shrink (ETC Part Number W6109-1.25) that is provided with each replacement patch bay cord.
Related Links/References
