Encoder Information - FSMS/VSMS
There are multiple encoder options that can be used with ETC Rigging 3rd Party Controls.
Fixed Speed Motor Starter (FSMS):
FSMS can provide a 5V or 24V encoder supply voltage.
  • TTL Encoder (Differential Signal, preferred)
    • 5-30 VDC Supply
    • 5V Signal
  • HTL or Line Driver Encoder (Single Ended Signal)
    • 5-30 VDC Supply
    • If encoder cannot run at 5 VDC an HTL -> TTL Conversion Card is required
  • HTL or Line Driver Encoder (Differential Signal)
    • 5-30 VDC Supply
    • If encoder cannot run at 5 VDC an HTL -> TTL Conversion Card is required, does not use differential signals
  • Quadrature Encoder (Single Ended Signal, preferred)
    • 5 VDC Supply
    • 5V Signal
  • 10k Analog Pot
    • Not recommended
Variable Speed Motor Starter (VSMS):
VSMS can provide a 5V or 24V encoder supply voltage.
    • 5-30 VDC Supply
    • 5V Signal
    • 5-30 VDC Supply
    • 5-30 VDC Supply
  • 10k Analog Pot
    • For use with SoftLift Fixed Speed Control Only, not reccommended.
Note: A motor encoder is required for full variable speed control, without a motor encoder a VSMS can only run a hoist in SoftLift (fixed speed).
Motor Control Interface (MCI):
MCI can provide a 5V or 24V encoder supply voltage.
    • 5-30 VDC Supply
    • 5V Signal
    • 5-30 VDC Supply
    • 5-30 VDC Supply
  • 10k Analog Pot
    • Not reccommended
Note: A motor or dum encoder is required when the 0-10V analog speed control on MCI is being used in a (non-overhead lifting) variable speed application (ie curtain machines, etc.).
ETC recommends using an encoder with a minimum resolution of 1024 pulses/rotation.
ETC recommends using Belden 9728 or equivalent for encoder field wiring.
Encoder Type Signal Level Supply Voltage Signal Output Voltage
TTL High 4.75 - 30 VDC 3V Min (5V Max)
  Low 4.75 - 30 VDC 0.5V Max
HTL* High 4.75 - 9 VDC 3V Min
  High 9 - 30 VDC Supply Voltage - 3V (Min)
*Requires an HTL -> TTL Conversion Card
