Reassigning DMX Port Universes on Hog 5
DMX port universes on internal console widgets and external HPUs automatically map but can be assigned.
How To Map An Output
  1. Start a New Show or launch an Existing show on the console
  2. Plug your widget into the Console or PC via USB
  3. Setup
  4. Network
    •  the Network window will open
  5. Click on the Processor which the DMX widget is attached. (this is most likely DMX Processor #1)
  6. Press the Settings button at the top of the Network window
    • the Processor Settings window will open
  7. Select the "Output” tab
  8. Press the Add Mapping button
  9. Select a starting and ending Universe
  10. Press the OK button
  11. Assign destinations and ports as preferred by clicking in the Port cell and choosing the desired output number
  12. Press Ok
If more than one dmx widget is plugged in, They can be beaconed from the system info tab in the control panel. Pressing the beacon button to the right of the mapping can help identify which widget has been mapped
