Configure USB widget with Hog 2 PC
How to connect USB DMX widget with Hog 2 PC
Steps to Solution
  1. Connect the USB DMX Widget or Super Widget to the computer's USB port
    1. When connected, the Link indicator on the widget should be illuminated and will blink every 2 seconds
  2. Right click on the Frontpanel and select Config
  3. In the DMX Outputs sections, select the drop down for the Port to output to and select the proper widget
  4. Click OK
