A fixture type is not in the fixture libraries of a Hog 3
A fixture type is not in the full fixture library.
A fixture type might not be in the fixture libraries on the Hog 3 because
- It was written after the last updated Hog 3 library
- It has not been written
- If it exists as a Hog 3 library, you can find individual libraries on the FTP site.
It is organized by manufacturer and then fixture name. As long as the file ends in.hog3lib.tar.gz
, it can be used on Hog 3 consoles. If the library ends in.hog4lib
, it cannot be used on Hog 3 consoles.- If the library is on the FTP site, then it can be added to the show file. Here are the steps to add a fixture library on a Hog 3 console.
- If the fixture library is not on the FTP site, then it has not been written. Hog 3 libraries are no longer being written by High End Systems. If you need the fixture type, you will need to use the Fixture Builder on the console to build it.
