DMX x 4 Output PCB, Dip Switch settings
There is a set of four dip switches on the DMX x 4 output boards used in Road Hog 3 & 4, Full Boar 3 & 4, Super Widgets, and Wings, etc.
  1. If the board is in a console it is considered an internal widget, and dip switch 1 should be on.
  2. If the board is in a Super Widget, or Wing, it is considered an external widget, and dip switch 1 should be in the OFF position.
  3. Dip switches 2-4 do not have any affect and should remain in the OFF position
