DMX x 8 Output boards, correct service part numbers.
The number silk screened on the DMX x 8 output board is an un-programmed board, 80030085EF will not work.
Use the service part numbers below
  1. Use part number 80030122EF for Hog 4, Hog 4-18, and Rack Hog.
  2. Use part number 80030112EF for the DP8000.
