PCBs, Playback Wing 4, Playback board and Playback Board CPU, correct service part numbers
The numbers silk screened on the PCBs are for the un-programmed PCB which will not work. Use the service part numbers below
  1. Use part number 80040050EF for the Playback PCB
  2. Use part number 80010232EF for the Playback CPU PCB
