Playback controls are not behaving as expected in Hog 4
Playback controls are not behaving as expected.
Check that the playback controls haven't been mapped to a different function other than the default.
- Open the Options for the List/Scene
- Select the Master Tab for the Masters control buttons
- Are the buttons assigned to the correct function
- Select the Main Tab for the Main control buttons
If you have performed all the troubleshooting steps in this section and the problem continues to persist then please contact High End Systems Support
