Replacing a DMX IO Board on a DP8000
Use this guide to replace a Power Supply on a DP 8000.
Tools required
  • #1 Phillips (cross-head) screwdriver
  • #2 Phillips (cross-head) screwdriver
  • 2.5 mm flat head screwdriver
  • 5/64 Allen Key
Steps
Important-Icon.png Power off the DP 8000 and disconnect its AC power cord before servicing
  1. Remove 14x allen screws. Those with RED circles (2x) are attached to the heat sink underneath and are longer than the rest.
  2. Put the cover aside and PCBs can be seen as below
  3. Remove 6x Phillips head screws and disconnect ALL connectors on the PCB. The connectors are labeled for easy reconnection
    clipboard_ea2d2f2099132c0a036f3f97e3a034386.pngclipboard_eb1abaafc5a9bbc9dcac58e851f53dd11.png
  4. Undo 16x screws so that the whole PCB is free to be removed
  5. Verify the DIP switch setting of SW2 on the NEW DMX IO board match the one you just replaced
    The DIP switch settings should be:
    1 - ON
    2 - OFF
    3 - OFF
    4 - OFF
  6. Take out the old DMX IO board and put the new one in. Follow the steps in reverse to complete the replacement.
The part number for the PCB, DMX Output is 80030112EF.
