Road Hog 4 does not recognize internal DMX widget
The Road Hog 4 does not recognize the internal DMX widget inside the console.
  1. The power to the widget is unplugged
  2. The dip switches on the widget could be wrong
  1. Make sure the widget has power
    Circled in orange is the power connector
  2. Set the dip switches in the proper position
    Dip switch 1 should be on
    Circled in green is the dip switch configuration
  3. If solutions 1 and 2 did not fix the issue, the widget needs to be replaced.
