Replacing the Power Supply Unit on a DP 8000
Use this guide to replace a Power Supply on a DP 8000.
Tools required
  • #1 Phillips (cross-head) screwdriver
  • #2 Phillips (cross-head) screwdriver
  • 2.5 mm flat head screwdriver
  • 5/64 Allen Key
Steps
Important-Icon.png Power off the DP 8000 and disconnect its AC power cord before servicing
  1. Remove 14x allen screws. Those with RED circles (2x) are attached to the heat sink underneath and are longer than the rest.
  2. Put the cover aside and PCBs can be seen as below
  3. Undo 4x Phillips head screws and unplug 3x connectors on the PSU. The four screws are circled in yellow below
  4. Take out the power supply and put the new one in and follow the previous steps in reverse.
Below are the connector descriptions.
The part number for a DP8000 power supply is 99070017EF
