All Hog Software Versions
The most recent release can be found on the Hog Product Page
The table below lists every version of Hog since v2.0.0 and its corresponding release date.
You can click the software version to download the release notes for that version
Software does not have to be installed in order; software versions can be skipped if you are updating software on a desk.
Version 5
| Version (click for release notes) |
Release Date |
Key Enhancements | Show File Compatibility | Library Compatibility | Software Downloads | Upgrade or Full Install? |
| May 2026 |
Forward: N/A (Latest Update) Backward: 5.0.0 |
V5 Fixture Library |
Upgrade only available if currently running 5.0.0 or later All other versions require a full install |
| 5.1.0
March 24, 2026 |
Forward: 5.2.0 Backward: 5.0.0 |
Full install Required |
October 8th, 2025 |
Forward: 5.1.0>5.2.0 Backward: 5.0.0 |
Upgrade only available if currently running 5.0.0 All other versions require a full install |
September 9th 2025 |
Forward: 5.0.1>5.2.0 Backward: NOT Backward Compatible |
V5 Fixture Library | Full Install Required |
Version 4
Release Date | Key Enhancements | Show File Compatibility | Library Compatibility | Software Downloads | Upgrade or Full Install? |
October 1st, 2025 |
Forward: 5.0.0>5.2.0 Backward: 4.0.0>4.2.0 |
Upgrade only available if currently running 4.0.0, 4.1.0, 4.2.0, or 4.2.1 All other versions require a full install |
November 5th, 2024 |
Forward: 4.3.0>5.2.0 Backward: 4.0.0>4.2.0 |
Upgrade only available if currently running 4.0.0, 4.1.0, or 4.2.1 All other versions require a full install |
August 20th, 2024 |
Forward: 4.2.1>5.2.0 Backward: 4.0.0>4.1.0 |
May 28th, 2024 |
Forward: 4.2.0>5.2.0 Backward: 4.0.0 |
Upgrade only available if currently running 4.0.0 All other versions require a full install |
March 12th, 2024 |
Forward: 4.1.0>5.2.0 Backward: NOT Backward Compatible |
Version 3
January 21st, 2025 |
Forward: (File can be exported to v4.1.0+) Backward: 3.14>3.21.1 |
V4 Fixture Library |
August 20th, 2024 |
Forward: 3.21.2 (File can be exported to v4.1.0+) Backward: 3.14>3.21.2 |
Upgrade only available if currently running 3.20.0 or 3.21.0 All other versions require a full install |
May 28th, 2024 |
Forward: 3.21.1>3.21.2 (File can be exported to v4.1.0+) Backward: 3.14>3.20.0 |
Upgrade only available if currently running 3.20.0 All other versions require a full install |
January 15th, 2024 |
Forward: 3.21.0>3.21.2 Backward: 3.14.0 > 3.19.1 |
April 18th, 2023 |
Forward: 3.20.0>3.21.2 Backward: 3.14.0 > 3.19.0 |
Upgrade only available if currently running 3.16.0, 3.17.0, 3.17.1. or 3.19.0 All other versions require a full install |
December 6th, 2022 |
Forward: 3.19.1>3.21.2 Backward: 3.14.0 > 3.17.1 |
Upgrade only available if currently running 3.16.0, 3.17.0, or 3.17.1 All other versions require a full install |
February 23rd, 2022 |
Forward: 3.19.0>3.21.2 Backward: 3.14.0 > 3.17.0 |
Upgrade only available if currently running 3.16.0 or 3.17.0 All other versions require a full install |
November 8th, 2021 |
Forward: 3.17.1>3.21.2 Backward: 3.14.0 > 3.16.0 |
Upgrade only available if currently running 3.16.0 All other versions require a full install |
October 4th, 2021 |
Forward: 3.17.0>3.21.2 Backward: 3.14.0 > 3.15.1 |
V4 Fixture Library | Full Install Required | |
April 13, 2021 |
Forward: 3.16.0>3.21.2 Backward: 3.14.0 > 3.15.0 |
Upgrade only available if currently running 3.14.0 or 3.15.0 All other versions require a full install |
| Jan 25, 2021 |
Forward: 3.15..1>3.21.2 Backward: 3.14.0 |
Upgrade only available if currently running 3.14.0 All other versions require a full install |
Oct 6, 2020 |
Forward: 3.16.0>3.21.2 Backward: NOT Backward Compatible |
| Jan 28, 2020 |
Forward: 3.14.0>3.21.2 Backward: 3.9.0 > 3.13.0 |
V4 Fixture Library | Full Install Required | ||
| Sept 30, 2019 |
Forward: 3.13.1>3.21.2 Backward: 3.9.0 > 3.12.0 |
| April 23, 2019 |
Forward: 3.13.0>3.21.2 Backward: 3.9.0 > 3.11.0 |
| Feb 18, 2019 |
Forward: 3.12.0>3.21.2 Backward: 3.9.0 > 3.10.0 |
Upgrade only available if currently running 3.10.0 All other versions require a full install |
| Dec 19, 2018 |
Forward: 3.11.0>3.21.2 Backward: 3.9.0 |
| Aug 21, 2018 |
Forward: 3.10.0>3.21.2 Backward: NOT Backward Compatible |
| Feb 8, 2018 |
Forward: 3.9.0>3.21.2 Backward: 3.7.0>3.7.1 |
V3 Fixture Library | Full Install Required | ||
| Nov 6, 2017 |
Forward: 3.8.0>3.21.2 Backward: 3.7.0 |
Upgrade only available if currently running 3.7.0 All other versions require a full install |
| Oct 30, 2017 |
Forward: 3.7.1>3.21.2 Backward: NOT Backward Compatible |
| April 17, 2017 |
Forward: 3.7.0>3.21.2 Backward: 3.6.0 |
Upgrade only available if currently running 3.4.0, 3.5.0, 3.5.1, or 3.6.0 All other versions require a full install |
| Feb 27, 2017 |
Forward: 3.6.1>3.21.2 Backward: NOT Backward Compatible |
Upgrade only available if currently running 3.4.0, 3.5.0, or 3.5.1 All other versions require a full install |
| Oct 14, 2016 |
Forward: 3.6.0>3.21.2 Backward: 3.5.0 |
Upgrade only available if currently running 3.4.0 or 3.5.0 All other versions require a full install |
| Sept 12, 2016 |
Forward: 3.5.1>3.21.2 Backward: NOT Backward Compatible |
Upgrade only available if currently running 3.4.0 All other versions require a full install |
| May 25, 2016 |
Forward: 3.5.0>3.21.2 Backward: 3.2.0>3.3.1 |
| March 14, 2016 |
Forward: 3.4.0>3.21.2 Backward: 3.2.0>3.3.0 |
Upgrade only available if currently running 3.3.0 All other versions require a full install |
| Dec 14, 2015 |
Forward: 3.3.1>3.21.2 Backward: 3.2.0>3.2.1 |
| Oct 1, 2015 |
Forward: 3.3.0>3.21.2 Backward: 3.2.0. |
| Aug 27, 2015 |
Forward: 3.2.1>3.21.2 Backward: NOT Backward Compatible |
Upgrade only available if currently running 2.4.0, 2.5.0, 2.6.0, 2.7.0, 3.0.0, 3.0.1, or 3.1.0 All other versions require a full install |
| June 24, 2015 |
Forward: 3.2.0>3.21.2 Backward: 3.0.0>3.0.1 |
Upgrade only available if currently running 2.4.0, 2.5.0, 2.6.0, 2.7.0, 3.0.0, or 3.0.1 All other versions require a full install |
| April 27, 2015 |
Forward: 3.1.0>3.21.2 Backward: 3.0.0 |
Upgrade only available if currently running 2.4.0, 2.5.0, 2.6.0, 2.7.0, or 3.0.0 All other versions require a full install |
| April 15, 2015 |
Forward: 3.0.1>3.21.2 Backward: NOT Backward Compatible |
Upgrade only available if currently running 2.4.0, 2.5.0, 2.6.0, or 2.7.0 All other versions require a full install |
Version 2
Release Date |
| Jan 21, 2015 |
Forward: 3.0.0>3.21.2 Backward: 2.6.0 |
Upgrade only available if currently running 2.4.0, 2.5.0, or 2.6.0 All other versions require a full install |
| Dec 17, 2014 |
Forward: 2.7.0>3.21.2 Backward: NOT Backward Compatible |
Upgrade only available if currently running 2.4.0, or 2.5.0 All other versions require a full install |
| Oct 30, 2014 |
Forward: 2.6.0>3.21.2 Backward: NOT Backward Compatible |
Upgrade only available if currently running 2.4.0 All other versions require a full install |
| Aug 26, 2014 |
Forward: 2.5.0>3.21.2 Backward: NOT Backward Compatible |
| June 20, 2014 |
Forward: 2.4.0>3.21.2 Backward: NOT Backward Compatible |
Upgrade only available if currently running 2.0.0, 2.1.0, 2.1.1, 2.1.2 or 2.2.0 All other versions require a full install |
| April 28, 2014 |
Forward: 2.3.0>3.21.2 Backward: NOT Backward Compatible |
Upgrade only available if currently running 2.0.0, 2.1.0, 2.1.1, or 2.1.2 All other versions require a full install |
| Feb 12, 2014 |
Forward: 2.2.0>3.21.2 Backward: NOT Backward Compatible |
Upgrade only available if currently running 2.0.0, 2.1.0, or 2.1.1 All other versions require a full install |
| Feb 4, 2014 |
Forward: 2.1.2>3.21.2 Backward: NOT Backward Compatible |
Upgrade only available if currently running 2.0.0, or 2.1.0 All other versions require a full install |
| Dec 5, 2013 |
Forward: 2.1.1>3.21.2 Backward: NOT Backward Compatible |
Upgrade only available if currently running 2.0.0 All other versions require a full install |
| Nov 5, 2013 |
Forward: 2.1.0>3.21.2 Backward: NOT Backward Compatible |
