Fixtures in WYSIWYG cannot be controlled by Hog 4
Fixtures in WYSIWYG visualization software do not respond to Hog 4. The fixtures in WYSIWYG might look like they are receiving the wrong DMX values.
This issue might be caused by Hog 4 not running the visualizer stream, and the visualizer not being connected in the show file.
Note-Icon.png Note that after the 3.14.0 update, this setting can be found in the Control Panel / Startup Tab. (show must be logged off)
  1. Follow the steps in the Hog 4 manual to configure WYSIWYG for Hog 4 control
  2. At the Hog 4 start screen, press Settings
  3. Enable "Run Visualizer"
  4. Launch the show and make sure fixtures are patched in Hog
  5. Open the network window: [Setup]  → (Network)
  6. Click on the visualizer, and then click on Settings
  7. Under Detected Visualizer, choose WYSIWYG with the proper IP address
  8. Click OK
