Fixtures are being parked without hitting Park on Hog 4 OS
When selecting fixtures and adjusting values, fixtures are being parked automatically. You are not hitting the Park button.
This happens due to the Parked window being open. The parked window is an editor which gives it priority over the programmer.
- Check if the Parked window is open
- Look to the right of the command line and you should see the word Parked. This tells what the open editor is.
- Either, bring the Parked window in focus and close it or close all windows.
- If you have any views recorded with the Parked window open where you will need to program, re-record those views with the Parked window closed.
