Hog 4 TFTP Service keeps Hog 4 PC from installing.
When installing Hog 4 PC, you will receive an error that says the following:
Service 'Hog 4 TFTP Service' (hogtftp) could not be installed. Verify that you have sufficient privileges to install system services.
Here is a picture of what the error will look like
Hog 3 PC is installed on the computer and not allowing Hog 4 PC to install.
- Uninstall Hog 3 PC
- Run the Hog 4 PC installer again
- If you are still having issues, contact HES support.
If you need to run Hog 4 PC and Hog 3 PC on the same computer, install Hog 3 PC after Hog 4 PC has finished it's install.
