Programming the SolaPix 7, 19 and 37 on Hog v3 Software
The below instructions will walk you through getting individual Pixel Control, Macro Control and PixelMapping the SolaPix series on Hog v3 software. The below instructions are the same for the 7, 19 and 37 models.
Notes:
  • The Part User Numbers will vary between the 7,19, and 37 modes as the LED count is different
  • When creating the plot ensure the Master Part is not included in the PixelMap.
Individual Pixel Control
Set the following on the Fixture:
  • Base - N/A
  • Flex - Mode Disabled
  • Pixel - Mode Compound
Repro:
  1. Add and Patch a SolaPix 19 Base + Pixel
  2. Close the Fixture Window
  3. Hit the Clear Key
  4. Select just the Master Part
    • 1(.) Enter
  5. Put the Intensity at Full
  6. Dial the Cyan, Magenta, Yellow Encoder to 100%
  7. Dial the White Encoder to 0%
    • Fixture should no longer be outputting
  8. Select the Pixel(s)
    • 1.1 Enter
  9. Put the Intensity at Full
    • Just the Center Pixel should be on
  10. Apply a Color
How to have a Color on the Base with a different Color on a Pixel
  • Base - N/A
Repro:
    • 1(.) Enter
  6. Apply a Color
  7. Select the Cell(s) you want a different color
    • 1.2 thru 1.7 Enter
  8. Put the Intensity at Full
  9. Apply a Color
How to PixelMap: Color Content
This assumes you know how to build a Plot and assign a PixleMap Layer to the Fixtures. If you need a refresher please look at Section 20.0 of the Hog User Manual.
  • Base - N/A
Repro: Color Content
  2. Add a Pixelmap Layer
  3. Close the Fixture Window
  4. Hit the Clear Key
  5. Create a Plot with the SolaPix
  6. Select the Whole Fixture
    • 1 Enter
  7. Put the Intensity to Full
  8. Set the Cells so they are listening to the Plot
    • 1.1 thru Enter
  9. Apply the Pixlemap Layer to the SolaPix
    • Ensure the Master Part is not included
  10. Put the Pixelmap Layer Intensity to Full
  11. Apply a Movie to the Layer
  12. Color Movie
  13. Select the Master Part
    • 1(.) Enter
  14. Dial the Cyan, Magenta, Yellow Encoder to 100%
  15. Dial the White Encoder to 0%
  16. Select the Cells
    • 1.1 thru Enter
  17. Dial the White Encoder to 0%
Repro: White Content - then adding color
    • 1 Enter
    • White Movie
  12. Select the Master Part
    • 1(.) Enter
  13. Dial the Cyan, Magenta, Yellow Encoder to 100%
  14. Dial the White Encoder to 0%
  15. Select the Cells
    • 1.1 thru Enter
  16. Dial the White Encoder to 0%
  17. Select the PixelMap Layer
  18. Dial Yellow to 100%
  19. Content should be yellow
Note:
  • If you would like the Base to have a Color simply select the Base (1.) and apply a color.
How to Use the Flex Macros
Note:
  • Some Macros use all 4 Flex Layers so you might need to add color to them all before seeing the Macro run correctly. It will appear as if Intensity is off while the macro is running.
  • Base - N/A
  • Flex - Mode Compound
  • Pixel - Mode Disabled
Repro:  Applying a Color to the Macro with the Base OFF
  1. Add Patch a SolaPix 19 Base + Flex
  4. Select the Master Part and the 1st Flex Cell
    • 1(.) + 1(.)1 Enter
  6. Select the Master Part
    • 1(.) Enter
  7. Select a Macro
  8. Dial the Cyan, Magenta, Yellow Encoder to 100%
  9. Dial the White Encoder to 0%
  10. Select the Flex Cell
    • 1.1 Enter
  11. Apply a Color
Repro: Applying a Color to the Macro and then a different Color to the Base
  1. Patch a SolaPix 19 Base + Flex
  6. Select a Macro
  7. Apply a Color
  8. Select the Flex Cell
    • 1.1 Enter
  9. Apply a Color
How to Use Base + Flex + Pixel
  • Base - N/A
Repro:  Applying a Color to the Base, a different Color to the Flex and a different Color to the Pixel
  1. Patch a SolaPix 19 Base + Flex + Pixel
    • 1(.) Enter
  6. Apply a Color
  7. Select a Macro
    • 1.20 Enter
  10. Apply a Color
  11. Select the Pixel Cells
  12. Put the Intensity at Full
  13. Apply a Color
