Shortcuts Hog 4
The Pig button is a modifier key, similar in the way Shift or Control keys work on personal computers.
Examples
| PROGRAMMING & PATCHING | ||
| [Pig] + [Blind] | Fades changes when blinding and un-blinding (normal functionality is to snap) | All consoles |
| [Pig] + [Clear] | Undo | All consoles |
| [Pig] + (Flip) | Sends fixtures through the flip positions in reverse order | All consoles |
| [Pig] + (Park) | Un-parks selected fixtures | All consoles |
| [Pig] + (Touch) | Touches specified parameters and fixtures but as record ineligible | All consoles |
| [Pig] + [Live] | Selects all fixtures that are on stage regardless of intensity | All consoles |
| [Fixture], [Pig] + Fixture type | Select all fixtures of a particular type | All consoles |
| [Pig] + Encoder wheel | Allows fine adjustment of the wheel's value | All consoles |
| [Pig] + [Intens / Positn / Coulour / Beam / Effect / Time] | Steps backwards through the kind's wheelsets | All consoles |
| [Pig] + [Record] | Inverts the current kind masking scheme for that record operation | All consoles |
| [Pig] + [Merge] | Inverts the current kind masking scheme for that merge operation | All consoles |
| [Pig] + [Fixture] | Tokens the word "plot" on the command line | All consoles |
| [+] + Encoder wheel | Sets wheel to maximum value when the encoder is turned clockwise. Sets wheel to minimum value when encoder turner counter clockwise. | All consoles |
| [-] + Encoder wheel | Inverts wheel between positive and negative values when available (ex: gobo rotation) | All consoles |
| [/] + [Encoder wheel | When you have several fixtures selected, you can make all the values of a parameter the same as that of the first fixture | All consoles |
| [BKSP] + Encoder wheel | Knocks out the coordinating parameter value for selected fixtures in the current active editor | All consoles |
| [BKSP] + [Intens / Positn / Coulour / Beam / Effect / Time] | Knocks out the coordinating kind values for the selected fixtures in the current active editor | All consoles |
| [.] + Encoder wheel | Sets wheel to default value | All consoles |
| [.] + [Intens / Positn / Coulour / Beam / Effect / Time] | Sets all parameters of that kind to their default value | All consoles |
| [.] + [Fixture] | Restore the default values for all parameters of the current selection | All consoles |
| [Open] + [Fixture] | Opens the fixture window | All consoles |
| [Pig] + [Macro] | Stops the recording of a keystroke macro, OR stop the playback of a running macro | All consoles |
| [Pig] + [.] + Encoder wheel | Sets wheel to default value and mode | All consoles |
| [Pig] + [@] | When patching with View by DP enabled, un-patches the selected fixtures | All consoles |
| [Pig] + Intensity wheel | Increases / decreases intensities in proportion to their individual level | Only on Hog 4-18, Hog 4 |
| [Pig] + [Nudge Up] or [Nudge Down] | Increases / decreases the intensity by half the assigned amount (by default, this will result in nudging by plus or minus 5%) | Only on Hog 4-18, Hog 4, Full Boar 4 |
| [Pig] + Parameter wheel button | When the encoder wheel button is set to Adjust by One (default), this will decrease the value by one | All consoles |
| [Pig] + (Even) or (Odd) | Select even or odd fixtures from the current selection based upon fixture user numbers, or when working on fixtures with dotted notation, only the whole number portion of the user number is considered when determining odd and even selections | All consoles |
| [Group] + [Next] or [Back] | Selects the next / previous segment of fixtures as established by the segments and buddying parameters. For example if 16 fixtures are selected in segments of 4, and "next by segment" is turned on, then [Group] + [Next] will select fixtures 1<4, then 5<8, and so on. If "next by segment" is turned off, then [Group] + [Next] will select a fixture from each of the four segments. | All consoles |
| [Fixture] + [Next] or [Back] | Selects the next / previous whole number fixture (and any applicable fixture parts) within the current fixture selection | All consoles |
| [.] + [Next] or [Back] | Selects the next / previous fixture part of the currently selected whole number fixture(s) | All consoles |
| Hold [Pig] when dragging items in Plots | Override the -snap-to-grid function | All consoles |
| Hold [Pig] when pressing a show item in Plots | Tokens the show item to the command line without executing the item | All consoles |
| WINDOW CONTROL | ||
| [Pig] + [Open] + [Colour] | Opens the Colour Picker window | All consoles |
| [Pig] + [Open] + [Beam] | Opens the Media Picker window | All consoles |
| [Pig] + [Open] + [Fixture] | Opens the Plots directory | All consoles |
| [Pig] + [Open] + List of Scene Directory Item | Directory Item opens option window for the list or scene items that is pressed | All consoles |
| [Open] + [Cue] or [Cue] [Cue] | Open the editor window for current cue on the chosen master | All consoles |
| [Cue] + [Next] or [Back] | Step through cues in the Cue Editor window | All consoles |
| [Open] + [BKSP] | Closes active window | All consoles |
| [Open] + [Thru] | Cycles through open windows (change focus) | All consoles |
| [Open] + [Full] | Maximizes active window | All consoles |
| [Open] + [@] | Moves active window to the next screen | All consoles |
| [Open] + [/] | Copies and splits active window | All consoles |
| [Open] + [+] | Sizes active window clockwise | All consoles |
| [Open] + [-] | Sizes active window counterclockwise | All consoles |
| [Open] + [.] |
Hog 4 v3.17.1 and older - Toggles the window Unlock button Hog 4 v3.19.0 and newer - Closes all windows |
All consoles |
| [Pig] + (Size) | Cycles through the possible window sizes in the reverse order | All consoles |
| [Open] + [1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 / 9 / 0] | Opens view 1-10 | All consoles |
| [Pig] + (>>) on the View Toolbar | Changes view toolbar to previous page of views, rather than next page of views | All consoles |
| [Open] + First encoder wheel | Vertical window scroll (up/down) | All consoles |
| [Open] + Second encoder wheel | Horizontal window scroll (left/right) | All consoles |
| [Open] + Third encoder wheel | Zoom (plot window only) | All consoles |
| SPREADSHEETS | ||
| [Pig] + [Set] | Acts as a right mouse click | All consoles |
| [Pig] + Arrow keys | Allows for selection of multiple cell items in spreadsheets | All consoles |
| [Pig] + [BKSP] | Removes values from the currently highlighted cells in the Programmer or editor | All consoles |
| [Pig] + [Copy] | Copies the contents of the currently selected cells | All consoles |
| [Pig] + [Move] | Pastes into the currently selected cells | All consoles |
| DIRECTORIES | ||
| [Pig] + Arrow keys | Extends directory item selection | All consoles |
| [Pig] + Button in a directory | Overrides directory Guard button | All consoles |
| FILE BROWSER | ||
| [Pig] + Click on a file | Allows for selection of multiple files (Pig key is acting like control key) | All consoles |
| [Pig] + Drag a file to another folder | Creates a copy of the file in the new location | All consoles |
| PLAYBACK | ||
| [Pig] + [Release] | Releases all active cuelists and scenes | All consoles |
| [List] + [Release] | Releases any active cuelists not attached to masters on the current page | All consoles |
| [Scene] + [Release] | Releases any active scenes not attached to masters on the current page | All consoles |
| [Page] + [Release] | Releases all physical playbacks on the current page | All consoles |
| [Choose] + [Release] | Releases the selected master without changing the chosen master | All consoles |
| Holding [Choose] | Displays the master's playback rate, effect rate, effect size and intensity on main encoder wheels, change the master control set used by the pop up menu that appears above the playback bar, quick access to popular settings from the master's options, and hot swap the fader assignment by selecting the control from the encoder bar (the current control is outlined in blue) | All consoles |
| [Pig] + any of a master's playback keys | Release that master, regardless of the function | All consoles |
| [Pig] + [Choose] | Opens the options window for the selected master | All consoles |
| [Choose] + tapping [ || ] | Adjust effect tempo of the master with tap tempo | All consoles |
| [Choose] + tapping [ ► ] | Adjust chase rate with tap sync | All consoles |
| Flash key + [Pig] - Flash key - [Pig] | Latches the flash key until the flash key is pressed again | All consoles |
| [Pig] + Rate wheel restore key | Permanently store the rate wheel's modifications for a cuelist/scene master | Only on Hog 4-18, Hog 4 |
| [Pig] + [GM] | Acts as a DBO (Dead Black Out) key | Only on Road Hog 4-21, Road Hog 4, all HedgeHogs |
| [Pig] + Batch fader | Capture a variable parameter (for example intensity or playback scaling) from the cues/scenes in the batch to the fader | All consoles |
| [Pig] + [Next Page] | Acts as a Previous Page button | All consoles |
| [Pig] + Command Key | Releases the cuelist/scene linked to the Command Key | All consoles |
| CONSOLE / DEBUG | ||
| [Pig] + [Open] + [BKSP] | Opens the Launched Processes window (used to restart the Desktop after a desktop crash) | All consoles |
| [Pig] + [Open] + [1] | Opens the Log Viewer window | All consoles |
| [Pig] + [Open] + [5] | Opens the debug tool | All consoles |
| [Pig] + [Open] + [Delete] |
Restarts the console if held for 5 seconds *On Hog 4-18 holding this key combination for 5 seconds shuts down the console, then the keys must be released and held again for 5 seconds to boot the console |
All consoles |
| [Pig] + [Fan] + Up Cursor Key | Enables the front panel to be used as a keyboard during a full software install | All consoles |
| [Pig] + [Fan] + Down Cursor Key | Disables the front panel from being used as a keyboard during a full software install and returns it to Hog mode | All consoles |
| MISCELLANEOUS | ||
| [Pig] + [Enter] | Toggles the function keys between Kind Key and Command Key mode | All consoles |
| [Pig] + [Setup] | Toggles the work light on and off | Only on Hog 4-18, Hog 4, Full Boar 4, Road Hog 4-21 and Road Hog 4 |
| [Pig] + (Undo) | Redo | All consoles |
| [Pig] + on-screen keyboard key | Acts as a shift key, to type upper case characters | All consoles |
| [Setup] + First encoder wheel button | Calibrate touchscreens; quit calibration by pressing [Enter] | All consoles |
| [Setup] + Encoder wheel | Adjust brightness of LCD back lights, front panel LEDs, desk lights, and work light | All consoles |
| [Pig] + [.] | Toggles slot toolbar and encoder wheel toolbar on / off | All consoles |
| [Pig] + [0 / 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8] | Toggles the corresponding playback bar on / off | All consoles |
| [Pig] | Ideal key to wake console from sleep as it will not cause playback or place items on the command line | All consoles |
