Views are not recalled correctly when opened on different Full Boar 4s
A show file is shared between 2 FullBoar 4s and has views stored in it. The views are in two different scroll positions on the two consoles.
This is expected if the consoles have different revisions of displays since the two displays will have different resolutions.
In 2016, a newer, higher resolution display was introduced, which causes scrolling positions to not be in sync with the older displays.
The only solution is to have 2 FullBoar 4s with the same display model.
