All Halcyon Platinum Software Versions
NOTE: Be cautious when downgrading fixture software versions as this can affect many functions such as cooling/thermal adjustments, power adjustments, DMX channel count and the overall functionality of the product. HES recommends always updating to the latest version of released software.
The most recent release can be found on the Halcyon Family product page at:
https://www.etcconnect.com/Products/Automated-Lighting/Halcyon/Software.aspx
Version Release date Fixes Download link
v1.3.0 10/11/22
  • Initial production release
v1.4.1 01/18/23
  • First web-published version
  • Fixed bug relating to accuracy on Pan and Tilt when using Magnetic Sensor
v1.4.2 02/14/23
  • Position acceleration adjusted to prevent mis-step.
  • Color Linear is now the default setting for CMY curve.
v1.4.4 07/24/23
  •  Pan/Tilt encoder feedback times out when fixture is held out of position.
  •  Pan/Tilt homing issue when using effect engine fixed.
  •  Pan/Tilt position error when switching pan range from 540 to 630 fixed.
  •  mSpeed added to gobo and color functions.  New fixture library needed to access.
  •  Pan/tilt mSpeed off was added to the control channel.
  •  Park current of motors reduced.
  •  Fast mode added to CMY/CTO color mixing.
  •  Fix for network communication issue when running multiple universes of ART-net and sACN
  •  "Errors Detected" message added to display after homing with an error.
v1.4.5 08/28/23
  • Follow spot mode selection added to fixture menu.
  • Improvements made to fan control.
v1.4.7 02/22/24
  •  Autofocus calibration moved to settings in menu.
  •  FSM displayed when in follow spot mode.
  •  Fixed display bug that caused it to turn on when set to off.
v1.4.8 04/22/24
  • Pan/Tilt curve selection added to menu and control channel. (S-curve/Linear).
  • Adjustments made to fan control.
v1.4.10 06/19/24
  • Studio mode fan start voltage increased to account for component tolerances causing fan to not turn on.
  • Fixture software version and temperature menus moved to the first two options in Diagnostics.
  • Bug fix causing erroneous pan error after uploading.
v1.4.11 07/18/24
  • USB upgrade issue causing some USB drives to not be detected fixed.
  • Adds dual backup sectors to make sure fixture hours are saved.
Halcyon Platinum_V1411.NCW - USB
Halcyon Platinum_V1411.HYD - Uploader
Halcyon Platinum-Ver-1-4-11.zip - All files
