Halcyon Color Variations
Symptoms
CTO flags are slightly in
Color mix saturation is different between fixtures even though the console is outputting the same values
Resetting fixture defaults does not change the CMY Curve mode
Description
The fixture is in Color Linear mode- this allows more accurate color mixing on ETC Eos family consoles
Color Linear: Makes color mixing with color pickers as accurate as possible.
Mech Linear: Provides mechanically linear motion
Use preferred color mixing mode- insure all units are set to the same mode to insure even color mixing
Menu Navigation:
- Settings
 - Service *4116*
 - CMY Curve
