Halcyon Engine Replacement
Halcyon gobo colors look different between fixtures after engine swap
Explanation of Issue
The Halcyon fixtures have two light engine options: Ultra-Bright and High Fidelity.
Each engine type needs the accompanying mode set in the menu screen on the fixture. The Ultra-Bright Engine Type mode automatically inserts the CTB color chip when a gobo is used. This allows for color consistency and yellow reduction with gobos.
Change the LED Engine Type option in fixture menu settings
  1. Settings
  2. Service *4116*
  3. LED Engine Type
References
