Molded Insert/SIP Variations for Solaframe 750 and Solaframe 1000
SolaFrame 750 and SolaFrame 1000 use the same molded insert to easily fit into our universal 1200 x 600 mm road case. However each fixture had a prior molded insert that was not designed for our standard road case. Included below are the dimensional documents for these previous molded inserts
Current SolaFrame 750 and SolaFrame 1000 SIP.pdf
