Replacing LED Cooling Fans on Solaframe 1000
An LED fan has stopped spinning or its speed is no longer reading in the menu.
The fan has failed or its tachometer no longer works
  1. Measure the wire length of the failed fan and order the replacement with the same wire length.
  2. Fan Part Number          Fan Description
       B1111                               FAN LED 16CM
       B1110                               FAN LED 20CM
       B1112                               FAN LED 24CM
       B1109                               FAN LED 26CM
