Solaframe 3000 Gobos Not Working
Gobos will home correctly, but stop working when engaged.
  The gobo module fan is shorted internally and causing the gobo module PCB to fail. This fan is activated when gobos are put into the light path. When the shorted fan is activated it takes out the drivers on the gobo module PCB.
  1. Repalce the gobo module fan(part number B1086) and gobo module PCB (part number 2581B5004).
