Clear errors on display
Fixture displays an error
When the fixture experiences an error, the error is logged into the info error section.  The error will stay in this section of the information section until removed.
  1. On the display screen hold menu
  2. Go to set
  3. Service setting
  4. select PIN  50 is the pin number hit enter
  5. Clear errors ON enter
  6. Back out to main menu
  7. check errors
  8. Errors should be clear.
Related Links/References
