Lonestar Tilt Coarse Error
Symptoms
Lonestar fixtures may not home thier tilt correctly after a powercycle or fixture global reset. The position may be off a couple of degress  or up to 45 degrees and a Tilt Coarse error will be displayed. This will cause programmed postitons to be incorrect when recalled through pallets, presets, cues, etc.
We have corrected this intermittent issue in Lonestar software version 1.6.6. Please update your fixtures to this version or newer. Then clear the Error History in the display under service settings.
