Lonestar Snoot Accessory Installation Guide
ETC Installation Guide
High End Systems Lonestar Snoot Accessory
Congratulations on your purchase of the Lonestar snoot accessory (ETC part number 2550A1020). Review the Lonestar User Manual to familiarize yourself with the fixture before you install the snoot accessory. ETC High End Systems product documentation is available for download free of charge from the ETC website: etcconnect.com/Products/High-End-Systems
Installation
  1. Disconnect power to the fixture.
  2. Place the fixture on its base and lock the pan and tilt locks.
  3. Use a #1 Philips screwdriver to remove the two screws from the bezel. Set these screws aside for use later in this procedure.
  5. Insert the snoot into the bezel.
    1. Orient the snoot so that the two holes in the base of the snoot align with the two screw holes in the bezel.
    2.  Align the four slots in the base of the snoot with the four tabs on the bezel.
  6. Twist the snoot counterclockwise to lock it onto the fixture.
  7. Reattach the two screws to secure the snoot to the fixture.
Related Links/References
