Replacing LED Cooling Fans on Solaframe 1000
An LED fan has stopped spinning or its speed is no longer reading in the menu.
The fan has failed or its tachometer no longer works
- Measure the wire length of the failed fan and order the replacement with the same wire length.
 - Fan Part Number          Fan Description
B1111 FAN LED 16CM
B1110 FAN LED 20CM
B1112 FAN LED 24CM
B1109 FAN LED 26CM
