Fans Power Up in Continuous Modes When DMX Not Applied
Fans run continuously upon powering on the SolaFrame 3000 without data connected and do not shut off.
This was a bug found in software pre-dating v1.3.14 which was released on July 6, 2021. All subsequent software versions will contain this fix.
  1. All product should be updated to latest version of SolaFrame 3000 software.
  2. Latest/current software can be found here: https://www.etcconnect.com/Products/High-End-Systems/Lighting-Fixtures/SolaFrame/3000/Software.aspx
