All SolaHyBeam 3000 Software Versions
NOTE: Be cautious when downgrading fixture software versions as this can affect many functions such as cooling/thermal adjustments, power adjustments, DMX channel count and the overall functionality of the product. HES recommends always updating to the latest version of released software.
The most recent release can be found on the SolaHyBeam product page at:
https://www.etcconnect.com/Products/High-End-Systems/Lighting-Fixtures/SolaHybeam/3000/Software.aspx
Version Release date Notes Download link
1.3.0P Shipped on pre-released fixtures sent to LUX Lighting and TLS
  •    Self Test does not work
  • Original dim curve
  • Original CMY color mixing
1.3.0 2/20/20
  • Initial Production Release
  • Improved dimming
  • Improved CMY color mixing
v1.3.1 4/22/20
v1.3.2 8/24/20
  • CMY movement profile improved to reduce noise.
v1.3.3 01/25/21
  • Lens heater ramps up to full power one hour after turning on, to reduce internal haze.
v1.3.5 07/16/21
  • 100hz dimming mode added.
  • Dimming modes selectable thru control channel
  • Continuous and studio continuous fan modes dont power up fans until a DMX signal is applied
  • Led instability in 16khz dimming mode fixed.
SolaHyBeam 3000-Ver-1-3-5.zip
SolaHyBeam_V135.HYD - Uploader
SolaHyBeam_V135.NCW - USB
v1.4.1 12/06/21
  • Boot code changes will prevent SW downgrade to previous versions
v1.4.2 12/15/21
  • Bug causing DMX to Art-Net conversion failure fixed
HEW1000FX_1578 V142.NCW - USB
HEW1000FX_1578 V142.HYD - Uploader
SolaHyBeam 3000-Ver-1-4-2.zip - All files
Related Links/References
