AAS Panic and Work Light Stations
Panic station may have either a push button switch or a keyswitch. For push button stations, press [Panic] to switch panic channel on.
For keyswitch stations, insert key and turn one quarter turn and back to original position. Panic channel switches to full intensity immediately (fade time is always 0:00 seconds). To switch panic channel off, press [Panic] or turn panic key at any panic station. Panic station LED is amber when panic channel is not active; LED is green when panic is active.
Work light station
To switch work light channel on, press [Work light]. Channel fades to full intensity over fade time set for analog channels. To fade out work light channel, press [Work light] at any work light station. Work light station LED is amber when channel is not active; LED is green when it is active.
