How do I Disable the LEDs on the Echoflex Split Duplex Receptacle Output Controller (ERNR)?
I don't like the LEDs on the face of the Echoflex Split Duplex Receptacle Output Controller (ERNR). How do I disable them?
Answer/Steps
You can disable (or enable) the LEDs on the face by simultaneously pressing and holding the [LEARN] and [CLEAR] buttons on either side of the unit for 4 seconds.
  • If the LEDs were initially enabled, this 4-second hold will disable them.
  • If the LEDs were initially disabled, this 4-second hold will enable them.
  • Note: you will need to remove the receptacle's face plate to access the buttons.
Related Links/References
