EchoTouch Boots but Crashes when used
I have powered the EchoTouch from the EchoDin PSU and the EchoTouch will boot up correctly but as soon as its used then it crashes and reboots.
The Load indicator on the EchoDin PSU shows it running at 100% with only EchoTouch Connected
  1. Check the Wiring, it is likely that the EchoConnect is wired to the 24volt Connection of the EchoTouch.
  2. 24volts should be taken from the 24volt PSU.
Related Links/References
