Echo Inspire Control Station Buttons Stick Down
My Echo Inspire Station buttons get stuck down and do not have good action.
Explanation of Issue
Echo Inspire Stations (E1001, E1002, E1004, E1008, E1104) have a wall plate that secures to the station with built-in magnets, a plastic bezel that holds plastic button lenses, and screws that hold station into the back box.  When installed correctly, the buttons should freely move and should not feel sticky.
Potential Solutions
Some common issues that cause buttons to stick are:
  • The screws that hold the station in the back box are over-tightened.
    • If screws are over-tightened, button activation can be negatively impacted. Try loosening the screws.
  • Wall plate installed at an angle. Look for this and straighten it out.
  • Button lens(es) installed backwards or upside-down.
    • Lens should be slid on from outside toward the middle, starting at the hinge.
    • The lens will cover the entire button and click into place.
Please see the Inspire Station Installation Guide for additional details.
Related Links
