Echo Responsive Controls Inconsistent Timeouts (Auto Timeout)
My Echo Occupancy of Vacancy sensor turns off the lights after a different amount of time every time.
Why is the Timeout inconsistent on my Echo Occupancy or Vacancy Sensor?
The Echo Occupancy Sensors and Vacancy Sensors, both PIR and Dual Tech, are equipped with several options for vacancy timeout.  These options are set with dipswitches 3 and 4 on the physical station or via EchoAccess, provided the stations are in Custom mode.  The Timeout options are 5 minutes, 15 minutes, 30 minutes, and Auto.  After the set amount of time has passed since the last time the sensor detected occupancy, the sensor enacts a 30 second Grace Period. For more information on Grace Period, click here.
When dipswitches 3 and 4 are set to Auto Timeout, the timer starts at a 5 minute timeout. If the sensor detects occupancy after the 5 minute timeout but during the 30 second Grace Period, the lights will restore and the sensor will add 2 minutes to the vacancy timeout.  If then, after 7 minutes of no occupancy detection and the sensor does not detect occupancy during the 30 second Grace Period, the sensor will subtract 1 minute from the vacancy timeout. In Auto Timeout, the sensor will add 2 minutes for every trigger it receives during the Grace Period to a max of a 30 minute Vacancy timeout.  It will also subtract 1 minute for every Grace Period it does not receive a trigger for a minimum of a 5 minute timeout.  In this way, the sensor is constantly adapting to the needs of the space and the vacancy timeout is not a set amount of time.
  1. If Auto Timeout is not right for the space, change the dipswitches, or custom configuration, to choose a set vacancy timeout of 5 minutes, 15 minutes, or 30 minutes.
