Are the Ride-Thru Option Cards Interchangeable between SIQ and ERPs Last updated Save as PDF Explanation The Echo Relay Panel and Echo Relay Panel Feed Through use Ride Thru kit 7123K1017 while the Sensor IQ panel uses 7131K1004. These kits are not interchangeable, as they use different mounting methods.
