Sensor IQ Breaker Lockout/Tagout
I need to lockout/Tagout a breaker in my Sensor IQ.
To follow proper Electrical Safety it my be required to lockout/tagout a circuit being fed from a Sensor IQ panel.
ETC recommends the MasterLock 493B or the Brady 120/277v Clamp-On Breaker Lockout (65396). Not all standard lockout devices will fit the Sensor IQ breakers, but ETC has tested this one and it does function properly.
These Breaker are available from normal industrial suppliers. (e.g. Graybar, Grainger, etc.)
NOTE: These locks are not able to be placed side by side to lock out two neighboring breakers. If this is needed, the full panel should be powered down and locked out.
Related Links/References
http://www.masterlock.com/business-use/product/493B
https://www.bradyid.com/en-us/65396/prod-2024839.html
