Unison Legacy Error Message Chart
Upon starting and during operation of your system, the control module will display messages to indicate system status.
| DISPLAY MESSAGES | STATUS | SUGGESTED SOLUTION |
| System OK | System operating correctly | None required |
| Backup Active | Backup look playing | Turn backup look off |
| Test DMX Off | Test menu active | Restore DMX in test menu |
| Errors Exist/Dimmer Errors | 1 or more circuits have specific errors | Scroll through error list |
If errors exist, use the right arrow button to scroll through the list of circuits and associated errors. Multiple errors can be seen by pressing [▲] or [▼].
Possible error types include:
| DISPLAY MESSAGES | STATUS | SUGGESTED SOLUTIONS |
| SSP_ERR | Indicates I2C error | Cycle power - Call factory |
| No DMX | DMX is not being received | Hook up DMX or turn on console |
| DMX ERR | Bad DMX packets being received | Verify DMX wiring and termination |
| No Zero | One of the phases has failed to detect zero crossing. System is likely inoperable. | Call factory |
No Zero |
Call factory |
| Over Temp | One or more of the dimming modules has been shut off due to sensing of over-temp. | Make sure fan is running - Check rack filter - Check module input vents - Replace module. |
Voltage Low |
Rack is receiving insufficient voltage for initialized parameters. |
Verify input voltage |
| Voltage High | Rack is receiving excess voltage for initialized parameters. | Verify input voltage |
| Arch Failure | The control module has been configured as a CME/CMEd orCMB/CMBd and communication with the architectural processor cannot be established. | The control module must be configured as a dimming module in the [Rack] menu, or call ETC. |
| Bypass Active | A power failure in the normal power feed was sensed. Dimmers have been driven to full, bypassing all control. | Restore normal power. |
| CPU 01 - 06 Fail | A dimming processor in a -d module has failed. | Call ETC |
