Setting up a Loaner P-LCD
Thank you for taking advantage of ETC's loaner program. The steps below will guide you through setting up your new loaner and prepping your unit to ship for repair. If you run into any issues while following the setup process, please contact ETC Technical Services and hold off on sending your unit in (providing it's still functional enough to get by) until we can resolve the issue.
Removing the Broken Screen
  1. Grab the screen with your fingers on top and thumbs on bottom.
  2. Pull the bottom out, then lift up and towards you; the screen should come off with little to no resistance.
  3. Your touchscreen will have either 1 or 2 cables plugged into the back; remove them by pressing down on the small plastic tab and pulling straight out.
Putting in the Loaner Screen
  1. Put the cables into the same locations on the loaner touchscreen. If you have 2 cables, they will be different sizes — the larger one goes in the PoE net Connect port and the smaller one goes in the Lon LinkConnect port. If you only have one cable, it will go in the Lon LinkConnect port.
  2. Place the top of the loaner screen into the back box, making sure to slot the hooks on the back of the screen onto the pins on the left and right inside the box.
  3. Gently press the bottom of the screen into the back box. Once again, you should not encounter significant resistance while doing so.
Binding the Loaner Screen
Head to your paradigm processor and follow the directions in this article on how to bind a Paradigm station at the Paradigm Processor; after this, the loaner touchscreen should be fully operational.
Shipping Your Unit for Repair
Once you've followed the instructions to set up your loaner and are satisfied that it's working, pack up your unit in the box the loaner came in. Please send only the items on the repair order; unless instructed otherwise, do not send in any accessories, cables, or peripherals. If you do not have the appropriate packing material, contact ETC Technical Services.
Please ship to:
ETC, Inc
ATTN: RMA# <your RMA number>
3031 N Pleasant View Rd
Middleton, WI 53562
After the Repair
Repeat the steps above to put your touchscreen back in its place, then send the loaner back to the same address you sent your unit to.
