P-TS7 Comms Failure displaying on Battery Status Indicator
The battery status indicator on the "About" page of the LCD displays "Comms failure" instead of a battery percentage.
This occurs when the battery charging IC and the coprocessor are not communicating correctly.
  1. This is a hardware failure with the battery charging IC inside of the touch screen.
  2. The component is a 20pin QFN that requires surface mount repair.
  3. Please contact ETC technical support.
