ColorSource LCD has flickering white lines on ETC logo splash screen
Symptoms
Flickering vertical lines on the right side of the LCD that occurs during the ETC logo splash screen in the boot process
Explanation of Issue
This is a relatively common issue that is only present at boot-up. It affects primarily the right-hand side of the screen. It has no effect on the normal operation of the console
Though this issue does not affect normal operation of the console, if you would like this issue to be resolved, please contact ETC Technical Services to set up a repair
