ColorSource console stuck at Starting screen
The ColorSource console is getting stuck at the Starting screen
Bump LEDs are on and scrolling white, left to right
Attempting to delete show file data in the manufacturing app results in the progress bar getting stuck and never moving
Explanation of Issue
There are two causes for this issue. Either the FLASH chip has failed, or one or more DDR memory chips have failed. Most often, this issue is due to failing FLASH.
Show data is stored in FLASH. Should the FLASH fail, the console cannot access the show data, which gives the appearance that the show data has become corrupted. Deep clearing or deleting show data will not work in this case because FLASH cannot be accessed
Are my shows still OK?
If the FLASH has failed, then no. Recovering show files from a failed FLASH chip is impossible
  • Please contact ETC Technical Services
