ColorSource / EchoTouch Fixture Library Custom Manufacturer
I have a fixture whose Manufacturer is not listed in the ColorSource / EchoTouch Standard Fixture Library.  Instead, it's under the "Custom" Manufacturer when I search for it.
If the ColorSource / EchoTouch Standard Fixture Library includes just one or only a few fixtures from a particular Manufacturer, they will be listed under the "Custom" Manufacturer.  This shortens the total list of Manufacturers, as there are currently over 100 "Manufacturers" with only a single fixture in the Library.
The easiest way to find a particular Manufacturer / Model of fixture in the Library is to use the Search feature.
If the Manufacturer / Model for your fixture is not available in the Library, you can make a request to ETC to create one.  You may also create one using the ColorSource Personality Editor, which can be downloaded here.
