ColorSource AV Will Not Output OSC
I have assigned the OSC Remote Control IP address and the send/receive ports. But I cannot get the console to output OSC.
The ColorSource AV does not output OSC strings until it has received an OSC string. Each time a ColorSource AV is powered on (or awakened from hibernate), you must send the console an OSC string before it will begin outputting OSC.
