How To Disable RDM on ColorSource Consoles
The steps below will walk you through how to disable RDM on your ColorSource Console.
Please note that RDM is only running on the ColorSource Console when you are in the Patch Screen.
Steps to Solution
  1. Tap the {Setup} button in the bottom-left corner of the LCD.
  2. Tap {Patch}.
  3. In the upper-right corner of the screen, you will see a small {RDM} button. If that button is green, RDM is currently enabled. If that button is gray, RDM is currently disabled. Tap the {RDM} button to toggle between those two states.
Related Links/References
