My Console Stops Outputting When I Record A Cue or a Playback
If your console outputs while manually capturing channels and setting levels, but stops outputting after you've recorded a cue or a playback, check that the Masters above the touch screen are in the up position. Those faders are Masters for the function listed below them.
